If you want to upgrade the early 700R4 you can do what I did to mine. I have one in my 84 Trans Am and I went through B&M to get a "transkit". One of their complete rebuild kits. It's got larger valves and a shift kit included...don't recall the number off hand. Just look through their web site or give them a call and they should be able to tell you what to get. Runs about $300 for the kit. Anyway, even stock, the 700R4 will handle alot...easily what you want and with the kit, anything up through 450ish horse power and around the same amount of torque is candy. One of the most annoying things I noticed, was that they are timed to throttle position. When i'm in Overdrive, if I push the pedal 3/4 of the way down, it shifts out of OD and down to 3rd gear. Even if I'm up around 90, I have a hard time getting it back into OD...not sure if there is a way to fix that or not. Anyway, hope this helps!
If it's an 86, then you should have the electronic version, which is the newer style. Either way, for what you are running, it will be able to handle what you are trying to do to your motor.
Not always. The cable controlled 700r4 was used up into the 90's. What is it out of, and does it have a TV cable on the passenger side? |
early 770r4
yes it has the cable.i checked on the web somewhere that the first number is the year it starts with a 6.it is going in a 1963 gmc surburan with a 454 with low compression piston and a {RV cam} high rise and q-jet.it has been on the road for about 1 year with a th350.the trans was used and has started to slip a little. i`am going to go thru the transmission myself. it will be the second auto i have gone thru. thanks for all replys
| early hemi cuda project! need help shipping engines and building an early hemi | thecountmc | Hotrodders' Lounge | 13 | 12-03-2007 05:21 PM |
| 700r4 shift times is this ok? | evltwin | Transmission - Rearend | 1 | 04-23-2004 06:22 PM |
| Need advice: 700R4 banging in 1st | 360Camaro | Transmission - Rearend | 11 | 11-20-2003 06:44 PM |
| Early GM column shifter & 700r4 | 56xpresso | Transmission - Rearend | 2 | 07-17-2002 02:56 AM |
| early 700R4 | Paco | Transmission - Rearend | 3 | 03-10-2002 05:58 PM |
