Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Early 87 700R4 7 VANE PUMP TO 13 VANE UPGRADE
Old 03-10-2011, 08:18 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
no problems with a 13 vane set up. 10 will work just fine.
Set clearance of the rotor at .0015 - .002 for best results with flat surfaces in the pump and the stator cover is flat - smooth too
