Early 87 700R4 7 VANE PUMP TO 13 VANE UPGRADE - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2011, 06:01 PM
Is there any issues that I should be concerned about with upgrading the 7 vane pump to the latest 13 vane pump kit. I assume that it is better than the 10 vane kit.
Old 03-10-2011, 09:18 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
no problems with a 13 vane set up. 10 will work just fine.
Set clearance of the rotor at .0015 - .002 for best results with flat surfaces in the pump and the stator cover is flat - smooth too
Old 03-11-2011, 10:11 PM
13 vane pumps are designed to keep the 300mm converters full at road speed. Additionally they are the most prone to break the rotor under high load or increased horsepower. Use a 10 vane; they worked flawlessly for years.
oil pump upgrade whojohnjones Engine 9 07-18-2010 05:08 PM
Early SI Alternator Upgrade MI2600 Electrical 1 12-28-2008 10:41 PM
early 700r4 hdbiker Transmission - Rearend 6 01-23-2006 03:39 PM
Is the 13 Vane Pump worth it? dsmith1279 Transmission - Rearend 3 01-21-2005 09:02 AM
early 700R4 Paco Transmission - Rearend 3 03-10-2002 06:58 PM
