early 90s Ford Explorer rear ends - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2005, 01:55 PM
poncho62's Avatar
Wiki Edits: 5
Put a set of shocks on a buddies 2 wheel drive Explorer today..............It looks like a 9 in rear end under there....................Is it?
Ontario Rodders
Old 04-19-2005, 06:54 PM
tbirdscott's Avatar
stuff'n things'n whatnot
Pretty sure its the 8.8 dont they have disc brakes?
Old 04-19-2005, 07:08 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
From all of my times researching this, the Explorer was only optioned with the ford 8.8 inch axle.
If I remember right the Explorer 8.8 didn't get disc brakes as standard issue until after 1999.
Old 04-19-2005, 08:11 PM
poncho62's Avatar
Wiki Edits: 5
OK...thanks
The reason I asked, is that, it's is the "Pot" type rear, which iis what a 9 inch is. I thought that the 8.8s had the rear cover.........
Ontario Rodders
Old 04-20-2005, 07:50 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Do you have a way to get a pic of it, All of my sources call for the Explorer to have a Dana 35 in the front 90-94 TTB/95-03 CV shafts, and the rear to have the Ford 8.8 inch for all years.
I found nothing different even in an online search????
Old 04-20-2005, 08:43 PM
poncho62's Avatar
Wiki Edits: 5
This one is 2 wheel drive...........wil try to get a picture.
Ontario Rodders
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
69 Nova rear ends? onecoomofo Transmission - Rearend 12 02-13-2004 10:03 PM
Ford 7.5" Rear End Traction-Loc Install nightrain_rod Transmission - Rearend 2 12-30-2003 06:38 PM
Converting Jag rear end to Ford 9" Jag Daddy Transmission - Rearend 5 12-25-2003 02:47 PM
rear differential for 46 ford rp1 Suspension - Brakes - Steering 1 09-08-2003 07:43 AM
