Early Bronco differential width, 9 inch or 8 inch? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2010, 02:55 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Were any of the early Bronco built with 8 inch differentials or were they all 9 inch diffs in the early years?
Were the wheel bolt patterns 5 x 5 for the early Bronco?
I've got a 1961 Bug Eye Sprite. I was told it has a narrowed differential via the use of a Bronco axle housing with the long side cut off and another short side tube Bronco housing welded on.
The housing is an 8 inch, with 5 lug on a 4.5 inch bolt pattern for the wheels.
This Sprite was built around 1972 - 73 with Ford V8 power
Old 12-31-2010, 03:46 PM
As far as I know, all the early Broncos were Ford 9 inch. The Trannys and transfer cases went through some small changes like Dana 30, 35, 40 and Ford and New Process. They were all 5 lug big car/pu bolt pattern.
Trees
Old 12-31-2010, 04:10 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
jeffs bronco graveyard can answer your ?
http://broncograveyard.com/
Old 12-31-2010, 04:30 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
i have the tag off the center chunk.. reads:
WCL - A
3.00 2LB 801
my research indicates a 1963 Fairlane diff, built in late 1962 with 3.0 gear
The width of the axle from wheel hub surface to hub is 49 3/8 inches
that width does not come up on the sites I have searched for difff widths
Old 12-31-2010, 05:04 PM
Footstomper
Last journal entry: 40 ford/cadillac coupe
I bought a 1967 Bronco rearend with axles
I pulled a 3.7 ratio 9" with saginaw 3 speed overdrive. I bought it for 35.00, after 5 years of driving with the forty coupe, I heard some sounds in the rear and I pulled the axles and saw where the housing was bent all that time. I think the bronco was a rock crawler. Took it to the speed shop and they rebuilt chunk and straightened with a new axle. It is now smooth.
Old 01-01-2011, 03:48 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
At this point, I know that it is not a 9 inch from a Bronco, since this differential is 8 inch.
I have tried to upload some photos I took of the narrowed axles on this unit. I think some folks here will enjoy the pics
There is a error message that pops up when I try to process the photos into the HR gallery. Hope Jon has an answer soon
Old 01-02-2011, 07:37 AM
Footstomper
Bronco 9"
I measured another housing with the rest of the 67 bronco. I think I remember the housing was about 58". I bought a axle from Bronco graveyard, the machine shop confirmed it as a 9". I wanted to get a housing of 9" with 59.5". That was the original of the 1940, 3/4" short on each side. Knowing now I can put a wider rear rims with fulling up the rear fenders with options. Since the 500 cad might light the 16x6.50 cokers, and they are very expensive.
11 inch brakes 14 inch wheel gearhead1964 Suspension - Brakes - Steering 5 12-21-2013 08:27 AM
68 Bronco, 9" differential questions jmbjs Transmission - Rearend 14 02-15-2008 09:28 AM
2 1/2 inch exhaust with 3 inch mufflers? newchevyman Engine 9 05-11-2006 01:37 PM
11 inch clutch vs 12 inch (engine swap) Morgangmc Transmission - Rearend 5 02-08-2004 08:14 PM
ford 9 inch width goose Transmission - Rearend 3 02-07-2004 05:05 PM
