Early Chrysler hemi power steering bracket - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2012, 12:50 PM
Does anyone have a PAW early hemi power steering pump bracket, HEM-5410; for sale or if not a tracing so I can fab one myself? PAW doesn't make them anymore and I want to place the PS pump low down on the driver's side and be able to regulate the tension
Old 03-01-2012, 04:18 PM
Wiki Edits: 49
Don't have one but here's a pic of one I made for the GM unit I put on my truck. Just took a little 3 /16" plate and some minor welding. It runs off the belt that runs the alternator and that's where the adjustment is for tension.
Centerline
HotRodsAndHemis.com
"Speed has never killed anyone, suddenly becoming stationary, that's what gets you." - Jeremy Clarkson
Old 03-02-2012, 05:22 AM
Thanks for the pic-Where is your alternator? Do you have plates on both sides of the pump (difficult to see near the engine) Could you make a slot instead of a hole to obtain tension if I can't use the alternator.( I have the Hot Heads bracket for the alternator that puts it low down on the passenger side
Old 03-02-2012, 01:35 PM
Wiki Edits: 49
I made my own mount for the AC and I think it was a Hotheads mount for the alternator and then used a rod between them for tension adjustment.
Centerline
HotRodsAndHemis.com
"If money is what makes cars fast, mine otta be going 400 miles an hour!". - Felix Sabates
Old 05-14-2015, 06:15 PM
Centerline
HotRodsAndHemis.com
What did you use for the high pressure connection? Mine seems to be really close to the block.
Old 05-14-2015, 09:46 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Centrline has not been around for quite a while so you may wish to start a new thread for your question..
Sam
power steering box with early hemi Frank Valentino Suspension - Brakes - Steering 5 12-18-2012 05:48 AM
Please Help!power Steering Bracket cutthroatkid Engine 1 12-24-2009 01:00 AM
SBC - power steering bracket SECTION25 Suspension - Brakes - Steering 19 05-09-2009 11:52 AM
early hemi cuda project! need help shipping engines and building an early hemi thecountmc Hotrodders' Lounge 13 12-03-2007 05:21 PM
power steering bracket tinman386 Engine 6 02-01-2007 10:23 PM
