early ford rear transverse spring re-attach - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2011, 11:22 PM
I have a 39 ford. Rear transverse leaf spring is attached on one side...how do I get it lined up on the unattached side so I can put the shackle plates back on?
Old 04-29-2011, 06:29 AM
There is a tool for that. It is a spring spreader. I have one
It is a piece of pipe with each end threaded ... one Right hand and one left hand. As you turn the pipe in the middle ... the tool ex-spans ... or retracts ... depending on which way you turn the pipe.
The one in the photo is a store bought one. Mine is homemade.
I got the photo off eBay.
http://cgi.ebay.com/ebaymotors/Ford-...item255f380d5d
DEUCE Suspension-Brakes-Steering MODERATOR
Old 04-29-2011, 12:38 PM
Thanks
Thanks Deuce! I'll give it a try.
Front suspension help, parellel to transverse spring? hoof Suspension - Brakes - Steering 2 04-21-2008 08:36 AM
32 Ford transverse spring questions.. F&J Suspension - Brakes - Steering 4 04-17-2008 07:45 PM
aftermarket transverse leaf spring type spindles stevel48 Suspension - Brakes - Steering 4 02-08-2005 12:08 PM
Early 50's ford rear FiddyFour Customline Transmission - Rearend 3 12-27-2004 02:10 AM
transverse spring & straight axle 26trackt Suspension - Brakes - Steering 3 01-18-2003 11:45 PM
