Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Early Ford Spindles -- Bolt Patterns
Old 09-29-2007, 05:11 PM
Youngster's Avatar
Youngster Youngster is offline
early Ford spindles -- bolt pattrens
I think you have a pair of '35 or '36 spindles. Have you cut the steering arms off the spindles? If you haven't, you can heat and reshape the arms. That's the good news. If you've cut the arms off, well I don't know of any after market arms for these spindles. If you've made bearing adapters and caliper mounts, I would think you would be skilled enough to whip up a set of steering arms. You already have half of the figuring done with the arms from CE.
