Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Early Ford Spindles -- Bolt Patterns
Old 10-04-2007, 04:40 PM
Youngster's Avatar
Youngster Youngster is offline
Early Ford Spindles--Bolt Patterns
Doug... The reason there isn't enough room for the bearing is because on the '35 - '36 spindles, the bearing was between the top boss on the spindle and the cup for the brake shaft on the king pin. Personally, I would call Jim at CE and order a pair of spindles to go with the arms you have from them.
