Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Early Ford Spindles fitting early Ford axles
Old 08-09-2012, 09:50 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
OK, beat me up for resurrecting an old thread . . . . . . . . OK, now that that is done, please interpret these early Ford hubs. Red one on right has larger OD inner bearing, same outer bearing as the two rusty ones on the right. It also has a smaller OD flange. The middle one has that funny neck but is otherwise dimensionally a match of the one on the right. The one on the right has bosses under the lug bolts so I am assuming brake drums when on the back of the spindle?
To make a short story long, I need one more of the one on the right with the bosses. Anyone have one they could spare? I have two of the red ones that are like new, would be glad t trade them for a good right one.
If anyone needs the center one (it is pretty pitted but bearings are good), I will give it to them.
