Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Early GM tilt-telescope column
Old 10-07-2012, 10:46 AM
41 kustom's Avatar
41 kustom 41 kustom is offline
My column is from a 65-68 olds I believe. I'm under the impression that that column was used in many different GM cars
from Chevys to Caddys. I found a part number for a 66 Chevelle that might interchange to your column.Auto zone Number sw 3027. Get all the info you can and find a parts store that has a car guy working there, not a make-
model-year guy. Good luck. The bearing should be easy being a GM.
The Following User Says Thank You to 41 kustom For This Useful Post:
Aerotech (10-08-2012)
