Early model roller cam in a later model motor? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2010, 12:11 PM
Hey everyone, I am going to trying to put a roller Crane cam out of a 1985 LT1 350 Chevy into a 1993 ZZ3 roller motor. I have been told that Crane cam part #119641 will not use the cam plate to hold it back and that I would need to use a pre 1988 cam gear and a Cam button.
Any thoughts will help.
Thanks Ricksgtx
Old 09-04-2010, 12:56 PM
bigdog7373's Avatar
Of course it's fast
I'm pretty sure that lt1 parts can only be used in lt1 engines, they are not interchangeable.
Old 09-04-2010, 02:12 PM
Hippie's Avatar
Last journal entry: HEI comparison.
Yes, you can put an "old style" roller cam in a factory roller block by using a cam button just like you would in a pre-roller and then you can use the factory roller lifters but there was no LT-1 in '85. The early style LT-1 was '70-'72 only and there are those that would argue that '71-'72 don't really count because of the lower compression.
Old 09-04-2010, 05:02 PM
bigdog7373's Avatar
Of course it's fast
Is this a gen 1 lt1 or the gen 2 with the tpi system?
Old 09-04-2010, 06:03 PM
Bigdog, This is a Crate ZZ3 motor 350 aluminum head (58cc)that came with roller cam and a duel plane intake set up with a 650 holly double pumper.
Thanks
Ricksgtx
Old 09-05-2010, 01:40 PM
Hippie, you are correct (as usual) no LT1 in 85 but what about the cam timing gear? do I need to get a older model cam gear along with the cam button?
Ricksgtx
Old 09-05-2010, 04:04 PM
Hippie's Avatar
Ricksgtx
Flattery will get you everywhere. I only wish I was correct as often as I think I am.
Yes, you will need the early style timing set.
Would this Isky Hydraullic roller cam work good for my combo eric32 Engine 9 06-18-2009 04:36 PM
Cam Help shsouthard Engine 18 03-29-2009 09:33 PM
Question about Roller cam wear. eric32 Engine 4 07-13-2008 01:17 AM
Roller cam question? tiresmoke55 Engine 2 10-29-2007 01:08 AM
IGNITION and CAM TIMING sum87mustang Engine 3 07-11-2003 07:52 PM
