early Mustang pitman arm - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2009, 06:39 AM
user151's Avatar
The early Mustang pitman arm has a tapered stud, not the usual tapered hole. Also it fits the 1" steering box shaft, not the later 1-1/8" so the pete and jakes aftermarket arm won't fit. (Even if it did I would prefer a less costly solution.)
I was thinking of getting the Speedway cross steer tie rod end (#910-02999) and cutting off the stud end, leaving the threaded shaft with the tapered hole....
Is anyone running side steer with the early Mustang box and pitman arm? What was your solution?
Old 05-11-2009, 07:03 AM
woodz428's Avatar
Troll Hunter
I believe that there is an arm with the smaller hole. I have the larger diameter box with an arm from speedway, I can't remember if they offfered a smaller version or it was another supplier....but I think you should still be able to locate one.What year box is it?? I thought they went to the larger splined shaft about '67-8, when they went to "rag" joints to separate the shaft from the box. If you can't locate an earlier style arm , it should be pretty easy to pick up a later box fairly reasonable...I have 3. I think someone is even reproducing them.
Old 05-11-2009, 07:21 AM
Last journal entry: Bringing home the 401 Nailhead
I replaced the steering box on the wifes 39 Willys. The previous owner used a worn out Mustang box. I found a replacement box but did not have a pitman arms. I found a pitman arm on eBay that had the tapered hole and 1 1/8" for the sector shaft. When dealing with eBay make sure the seller measures for the 1 1/8 shaft. Some sellers don't know there is a difference. If I could get past history of my buys I would let you know the seller but eBay doesn't supply that for buys over one year.
Old 05-11-2009, 08:55 AM
user151's Avatar
Thanks guys !
Thanks for your comments, I read the descriptions on egay and learned a lot about these early Mustang pitman arms. I see what I need now.
Google helped too.... I was told mine was a 1965, but apparently it is early '67
I found this useful page, may help others:
http://www.stangerssite.com/pitmanarms.html
Help 1969 mustang Toddclary Suspension - Brakes - Steering 2 04-27-2009 07:50 PM
early hemi cuda project! need help shipping engines and building an early hemi thecountmc Hotrodders' Lounge 13 12-03-2007 05:21 PM
pitman arm length Jzarczyn Suspension - Brakes - Steering 2 06-17-2006 08:48 AM
mustang 2 lower control arm bushings nomaddaddy Suspension - Brakes - Steering 1 02-14-2004 12:28 PM
EFI 5.0 in an early mustang! 68stang_99 Engine 3 08-21-2002 11:58 AM
