early nova disk brake conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2005, 08:55 PM
hotrod66_57's Avatar
Last journal entry: dolly
i have a 66 nova. as you may know, they only came with drum brakes, and small ones at that. i know you can get kits to swap the front brakes to disks but they run about $600 and up. my question it if there are any other model cars/trucks whose spindles/etc. would fit my Nova. it is already a 5 lug and i can get special disk brake spindles but if there are others that will fit i would like to know. also, what would be the difference in rotors for a 69 and up Nova and the ones that would come in the conversion kit. i understand the concepts of all this i'm just not sure that all of the terms i've used are correct and i may be totally off base on what i think will work but let me know please. if anyone has performed a similar conversion and could offer me some advice it would be greatly appreciated.
thank you,
hotrod66_57
Old 04-26-2005, 05:23 PM
jalopy45's Avatar
Check E-Bay. Saw several cheap sets on there recently
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
Old 04-29-2005, 01:55 AM
The National Nostalgic Nova Club used to machine drum brake spindles for disc brake use for ~$75 on an exchange basis. Maybe they still do. Contact info is at the bottom of this page: http://nnnova.com/discbrakes.html
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Disk brake conversion need help Loup Suspension - Brakes - Steering 3 08-18-2004 06:12 AM
Disk Brake Conversion 64 Galaxie bgray Suspension - Brakes - Steering 19 06-02-2004 11:38 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
disk brake conversion 39rodder Suspension - Brakes - Steering 6 06-02-2003 07:54 PM
