early shifts on th-350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2005, 05:50 PM
hello all i'm new to the site..
i installed a rebuilt th-350 in my s-10 . it shifts fine 1-2 then the 2-3 shift is way to early. almost like it goes from 1-3 .if i shift manually from 2nd it is fine has all gears adjusted kick down cable and modulater valve. also installed the b&m shift kit stage 2. in this light s-10 it'll spin every shift. thanx for any help.
Old 05-04-2005, 08:17 PM
johnsquicks10,
The condition of quick shifting is usally caused by a govenor malfuntion. I have ground the counter weights down on the govenor so the shifts happened at higher road speeds. I was told that when you "open" the oil passages by drilling the valve body this can happen and that working with the govenor will cure the problem.
Good Luck
Scholman
Old 05-04-2005, 09:50 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
were the governor springs changed?
Did the valve body kit come with replace springs for the PR valve and shift vales?
Did the kit come with a small spring for the modualtor valve?
Old 05-05-2005, 05:23 AM
thanx for the help guys
the tranny shifted like that before i put the kit in it. the kit was just the separator plate and spacer support plate. kit part #30262.
again thanx for the help
Old 05-05-2005, 08:04 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
we did not really provide help.
If the trany shifted like this before , there could a governor problem ( sticky) or a weak spring on the 2-3 shift valve..... a common item.
the parts you added would not alter shift timing at all. Springs and weights do that.
Old 05-05-2005, 08:17 AM
willys36@aol.com's Avatar
Wiki Edits: 21
When I have run across early or non-shifting problems in a TH tranny, the vast majority of the time I have found the governor was screwed up - broken springs, sticking body, etc. Easy to pull so crawl under the car and jerk it out!
Cam/Lifter Question about Ramjet 350 Jake Harsha Engine 20 07-07-2010 06:22 AM
Why not a 350 sbc? bowtieorbust Engine 29 09-05-2008 09:43 AM
possible 350 block purchase - comments please idrva55 Engine 17 12-09-2007 09:29 PM
Does a Chevy 6.0 motor mounts line up with a early 90s 350 Justin Mc Engine 1 11-24-2004 05:03 PM
adapting early sbc intake manifold to 1987 350 heads steve curtis Engine 1 06-13-2002 02:56 AM
