Early SI Alternator Upgrade - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2008, 04:07 PM
MI2600's Avatar
Member# 3287
A friend has a '72 Chevy truck he uses for plowing. His plow set-up is electric. So, he'd like to upgrade his old SI style alternator to maybe 94 amps.
I know Harbor Freight used to sell upgrade kits for the SI, but apparently not any longer.
Anyone know where an upgrade kit might be purchased? My friend wants to keep the truck original, but will go to a CS style if he has to.
Old 12-28-2008, 09:41 PM
75gmck25's Avatar
I replaced the 63 amp 10si on my '75 GMC with a 94 amp 12si.. My alternator is mounted high on the passenger side, plug is clocked at 3 o'clock, and the 12si I bought was a direct replacement. I also upgraded the charge wire to 8 gauge with a 12 gauge fusible link. I ran the wire directly over from the battery positive to the alternator.
You need to find an SAE (not metric) 12si with a V-pulley (not serpentine) and it should be a very easy swap. If you can't find the right number, I think I could probably find the receipt for mine and get a parts number from it.
Bruce
Early Ford Spindles fitting early Ford axles pasadenahotrod Suspension - Brakes - Steering 3 08-14-2012 07:20 PM
newbie question about early engines toddwallace Engine 12 12-17-2008 03:29 PM
A question for the solid axle, king pin, early ford spindle kind of guys... Centerline Suspension - Brakes - Steering 11 02-17-2008 03:57 PM
early hemi cuda project! need help shipping engines and building an early hemi thecountmc Hotrodders' Lounge 13 12-03-2007 05:21 PM
early comet engine swap (or early mustang) REALGONEKATT Engine 14 11-04-2007 06:15 PM
