early turbo 400 bolt to edelbrock crate motor? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2009, 10:50 AM
does anyone know if this will work? my buddy needs to know. he was positive i could tell him and i dont have a clue. they didnt have "edelbrock crate motors" back in the day. i am assuming it will bolt right up, i think think the bolt pattern has been the same for small blocks and big blocks from the 265 up till now. any issues with flywheel/flexplate fit? how about the starter? thanks.
Old 05-17-2009, 11:01 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
Bolt pattern is the same for Chevy engines.
Starter, you have the 153 and 168 tooth ring gears, and the blocks and starters usually have accomodations to fit either one, there ARE some exceptions on the older blocks. Easiest way to tell, on the starter mounting pad, if there are 2 holes drilled and tapped for the starter, it's a 168 tooth only, 3 holes- 153 OR 168.
If the engine is an 85 or older it has the 2 piece rear main seal, and the 86 and up has the 1-piece seal, the flexplates and flywheels ARE different for these two engine years, they have a different bolt pattern, and the center hole is different, the newer ones have a balance weight- whereas the 85 and older were neutrally balanced, they won't interchange.
Old 05-17-2009, 01:19 PM
thanks, M&M. that should be all he needs to know. hey, nice pic's in your gallery. i drive a dump truck for the highway dept. i get to see some interesting stuff at work too. thanks again.
How much clearance should there be between motor mount and motor mount bolt? firstgear Hotrodding Basics 8 03-21-2013 09:10 PM
Cheap GM HVAC blower motor fix. M&M CUSTOM Electrical 8 05-17-2009 11:10 AM
Cam choice for new GM 260hp crate motor Iceberg Engine 3 02-21-2005 11:03 PM
Edelbrock or GM crate motor?? HotRodMan Engine 10 01-05-2003 09:56 PM
GMPP CRATE MOTOR Intake Manifold Vacuum alligator Engine 6 09-18-2002 07:02 PM
