easiest way to build VW console
1970 beetle..
i want a wood console.. is it easier to order one.. or just make one? i dont really know how.. but i can try=D |
I would certainly encourage a young fellow to make one as the skills you will recieve will be good down the road sometime..
Sam
i'm not sure how to make the area around the hand brake.. i feel sure i could make it no doubt but i need some ideas |
Take some card board and packing tape and make a mockup of your idea..then use the mockup pieces as patterns to cut your wood pieces..may take several tries to get just what you want..
Sam
Great answer, OMT. This is a great project to start with. My first project was a 60 VW. There is a ton of aftermarket stuff available for a VW. (Is it at all disconcerting to the rest of you that this young man has the computr skills to navigate this site better than most of us? O.K. me.) BTW. I made plans and God is hyperventilating.
The only thing you have to remember when using this method is that the thickness of the wood will be a bit different than the cardboard you'll most likely use for the prototype. Most woods are actually anywhere from 1/64" to 1/32" thinner than it's advertised thickness. This might not sound like much, but it can lead to ugly gaps in joints if you're not careful. Measure the thickness of the wood you want to use for your final piece with a set of veneer calipers ($15 at Home Depot - cheaper at Harbor Freight) and adjust your measurements accordingly when it's time to start work on the actual piece and you'll be okay. Don't be afraid to experiment - cardboard, hot glue, and tape are cheap. |
Dusty: So then you know what a flitch of veneer is, eh?
Actually "flitch" currently has two meanings when it comes to veneer. It's a flat piece of wood that is moved along the veneer cutting blade from which veneer is actually cut, and it's a stack of veneer cut from a single board (usually 8 pieces.) Eight pieces because that's what they could cut out of one average board while minimizing waste. You have to remember that this was before there was such a thing as the modern technology like we have today. Now veneer is made by basically "unpeeling" a log using computer controlled, high-speed cutters mounted to a rather slow turning lathe that can turn an average log into several thousand linear feet of veneer. Back in the day, you had woodworkers hand sawing logs into nominal sized planks, and then hand sawing those planks into veneer. That's still done today in the case of extremely rare species and top dollar exotics, and then usually only for small projects like jewelry boxes and such. I know lots of stuff - just ask my wife... Yeah, right...
man yall sound like my grandpa.. telling all kinds of old stuff
lol i think i'll build it out of 1/2" .. oak is expensive.. i think.. last time i checked.. but a good looking console is worth it.. i'll house a gauge panel and a compartment box then the slot for the shifter.. and a few little boxes and compartments.. mabye .. if its not too hard maybe a close-lid compartment.. and have it covered by a friend of mine who does upholstry <i dunno how to spell it> |
Have someone else do it for you since you obviously have no skills.
I usually handle these things with a PM, but you don't even deserve that.
Ontario Rodders |
Good on you Poncho
...just got the response in the mail..Sam
man just go away and leave us alone |
Good call Poncho!
| Recent Interior posts with photos |
| build a moter or buy a car first? | Tryin2MakeIt | Engine | 19 | 12-13-2006 09:43 PM |
| 350 build up opinions? | Artemis Entreri | Engine | 17 | 08-09-2006 01:48 PM |
| Intro and ? about center console build. | allenzalley | Introduce Yourself | 4 | 01-11-2006 04:26 PM |
| Camaro Console Gauges | Bluepen | Interior | 1 | 05-16-2003 06:15 PM |
| How to make a new center console? | Jag Daddy | Interior | 7 | 05-14-2003 10:22 AM |
