Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Eastwood Extreme Chassis black
  #16 (permalink)
Old 04-17-2013, 09:30 AM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
Originally Posted by Lizer View Post
I don't see where it says no epoxy...only no self-etching primers. And Epoxy is not a self etching primer just because it can go on bare metal.
Your right, and most paints will stick to epoxy and not let go...Epoxy isn't an etch so the Eastwood paint should stick to it...it's just one of those things that require trial and error, hopefully this time it will hold up. As I mentioned, after you talked to the Eastwood rep he basically told you the same thing I did with respect to not enough solvents being evaporated from the epoxy, this time I feel you should be good to go.
Ray
