Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Eastwood TIG
Thread: Eastwood TIG
Old 07-18-2011, 06:25 PM
RippinRon's Avatar
RippinRon RippinRon is offline
If you want to do aluminum and have decent results you need a squarewave machine that has adjustable ac balance. With a squarewave machine you can use thoriated, ceriated or lanthanated tungstens that are ground to a point on aluminum. You get a narrower arc a can focus the heat better. The new inverter machines are pretty slick they are light and use little power.
