Easy 12V Benchtop Power Supply - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2009, 08:56 PM
oldschoolrods's Avatar
Last journal entry: Engine Compartment
Article Here
I built one, works good, had the power supply laying around probably cost about another $20 using stuff at radio shack. If I were to do it again or do another one, I would not solder the wires to the binding posts, I'd use ring terminals. And if you do solder the wires, make sure to cover the board with something I learned this the hard way
Here are pics of mine
PS Radio shack only had black and red binding posts so I painted the other ones
ID:	40957   Click image for larger version
Old 09-29-2009, 09:05 PM
302 Z28's Avatar
I built one also, not enough umph to run my 12 volt battery chargers for my R/C planes.
Vince
Old 09-29-2009, 09:20 PM
Hey vince just curious what wattage supply did you use? so far the only thing I've powered with this was a cb radio I had lying around and it seemed to work ok.
Old 09-30-2009, 08:12 AM
302 Z28's Avatar
I actually tried two, one was 250w second one was 450w. I knew the 250w was probably too small, but tried it anyway. The 450w kept tripping out when I tried to run three Bantam battery chargers off of it. It may have been bad, as it was used and I got it free from the local computer geeks.
Vince
Old 10-03-2009, 05:47 PM
I did that also to run my battery charger for an RC plane? What else do people use it for? I'd guess you could run a car stereo to provide tunes in your garage. You could use it when you want to do that chemical bath thingy to remove rust. Anything I'm missing?
Old 10-04-2009, 02:58 AM
Last journal entry: Long time no journal entry, pulled hood tonight.
I would guess for testing electrical parts.
Old 10-04-2009, 12:52 PM
Yep thats exactly what I am planning on using it for
Stick welder - power supply vorgath Body - Exterior 30 10-26-2004 07:56 PM
Power Steering and Power Brakes blindboarder711 Suspension - Brakes - Steering 1 02-09-2004 03:54 PM
Car Audio Question Thuggishruggish3000 Interior 14 12-23-2003 09:48 AM
Hotrodders Knowledge Cluster: Power Steering Conversions Jon Suspension - Brakes - Steering 0 09-04-2003 12:20 AM
power steering too easy Paul K Suspension - Brakes - Steering 3 03-28-2003 05:01 PM
