Easy cold start, hard hot start - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2008, 01:30 PM
80 SS El Camino
Hey guys,
My SBC seems to crank within seconds when cold, no matter how long it has sat. If I run it to work, errands ect.. it takes forever to crank over. My guess is the wrong type of plugs or something simple like that. It has HEI and the battery and alt. are fine. Any ideas on why after the engine is at operating temp it just want to crank on and on for a while until it kicks over?
Thanks
Darrin
Old 08-10-2008, 01:35 PM
Luiz's Avatar
ChevyNut
Maybe the solenoid gets hot. When it cools down the starter spins freely enough to start the engine. It seems to be a common problem with small block Chevys.
Old 08-10-2008, 01:36 PM
I am not going to speak of your problem specifically but I have seen that similar problem happen alot when they can't get the car to restart when it is hot, and that tends to be because the starter motor is going bad. I am not sure of all the mechanics of why the starter goes, but typically a new starter cures the problem for me
Old 08-10-2008, 01:37 PM
IMO fuel not ignition.
Old 08-10-2008, 01:45 PM
Luiz's Avatar
ChevyNut
Sometimes a Ford remote solenoid, that is located far from the hot areas of the engine is the solution for the Chevy hot starting problem.
Old 08-10-2008, 01:47 PM
80 SS El Camino
I haven't noticed the engine spinning much slower when hot but I really haven't payed attention to that........ yet.........
I will do that, do you think moving the solenoid will help?
Darrin
Never mind, I see the post just above mine, thanks!
Old 08-10-2008, 03:11 PM
80 SS El Camino
I just did an exhaustive search on hot start problems and found the Mad Electrical "Start'M up kit" here is a cut and paste.
http://www.madelectrical.com/catalog/st-1.shtml
(2) SLOW CRANKING, a gr-r-runt, gr-r-runt. This kit won't fix it! You'll need to work with ignition timing, battery cables, the starter, and the rest of the system.
So I'm back to square 1. My timing is sitting at 10 deg, should I try backing it off or advancing it more? Again, this only happens at operating temp, not when cold.
Old 08-10-2008, 03:17 PM
If the ignition doesn't have enough oomph to make her pop, install an MSD-6.
Old 08-10-2008, 04:58 PM
Jmark's Avatar
You say that when hot, it CRANKS AND CRANKS, personally, i'd rule out any kind of starter or solonoid problem. It's fuel related and very common when hot engines sit for a while. It's called "hot soak".
The fuel bubbles in the bowl and dribbles down the primary nozzles flooding the engine.
There are a few things that may help.
Make sure the float level is right. What kind of carb is it?
Make sure the needle and seat are good and not letting fuel leak by and overfill the bowl.
Make sure the engine is not running overly hot.
Just for grins, next time you go somewhere, if you can, pull up, shut it down and then raise the hood and go do your errands. When you come back, close the hood and try to start it. The extra cooling may lead you in the right direction.
Mark
Old 08-10-2008, 07:21 PM
80 SS El Camino
Thanks jMark
I have to agree with you for the most part. The carb is an Edlbrock performer series.. 600 cfm if I'm not mistaken.
My opinion is it's one of two things
1. The fuel issue you mentioned
2. Wrong type of plug or weak plug wires.
Ill try your suggestion first, that ones free! If no luck Ill beef up to 8mm wires and do some research on plugs. To be honest I just bought this el camino and I have no idea what type of plugs are in it now.
Thanks
Darrin
Old 08-10-2008, 08:05 PM
Jmark's Avatar
Hi Darrin... One other thing. After if finally does start after sitting hot, does it blow black smoke for a second or two?
My truck does that on a quick shut down and re-start. It's HOT here and with the A/C on, under hood temps get up there. Cold, it fires in milliseconds but hot is a different story, black puff every time. I"m just too lazy to mess with it right now.
Mark
Old 08-10-2008, 08:12 PM
80 SS El Camino
jMark,
Cant say I've seen any black smoke. The motor is super strong with less than 2K on it. The car is *almost perfect* for an 80 El Camino. If not for the embarrassing hard start it would that much closer.
I'll keep my eye out for the smoke and any other symptoms, meanwhile, I'll be sweating my @%% off here in NC until it gets a little cooler!
Old 08-10-2008, 08:15 PM
Wiki Edits: 31
I have a '65 Rambler with a 196 6cyl and a B/N NOS carb, does the same thing. except in my case, it's just a common problem with that carb ( Carter RBS 1bbl ).. 2 pumps of the gas when it's cold and it fires right off. or a quick restart after shutdown, but any length of sitting and the gas in the bowl soaks the heat
Old 08-11-2008, 05:08 AM
Luiz's Avatar
ChevyNut
Darrin
Well, maybe it'd be necessary to check the condition of the starting system and timing first. If everything is OK, maybe a remote Ford solenoid will do.
Old 08-11-2008, 07:42 AM
Holder350's Avatar
Auto Parts Professional
just remember if it is a hot soak issue there are plenty of heat insulating spacers for carbs.
On a side note....my camaro has a cheapo $25 battery on it, and it spins fine.
All I had to do was put the coil on a toggle switch so that I could turn it off, start cranking to get fuel into the cyls and then flip it on! Otherwise, it will NOT crank cold because of the timing.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Car Hard to start?? HotRodMan Engine 7 03-12-2004 10:26 PM
Cold start problem CorvetteSteve Engine 1 04-14-2003 05:08 PM
Hot start problem-Not starter related Catalina Engine 4 11-13-2002 04:54 PM
hard starting when hot..fine when cold, suggestions? HotRodF100 Engine 10 04-16-2002 08:24 PM
Hard Start Question Jim Weeks Engine 6 03-19-2002 04:30 AM
