easy pedal clutch - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2006, 04:38 PM
easy pedal clutch
Hi, anyone have experience with an easy pedal clutch to put in a 327 / around 325 hp 64 vette. it should be good for some aggressive driving but also easy to push in for my wife to drive.
Thanks, Frank, fgvdew@aol.com
Old 12-02-2006, 06:22 PM
Last journal entry: frame build
Put the stock Vette clutch back in. Very tractable clutch for all around use. The stock diaphram clutch has probably been replaced with a Borg-Beck type. These have a higher pedal pressure and hook better but the stocker will last many many miles under average use. GM doesn't like replacing clutches either and they assumed they were going to get hammered occasionally .
Old 12-03-2006, 11:59 AM
easy pedal clutch
Thanks,
Any experience with a centerforce diaphram clutch, the 64 vette had a 10.4 " clutch.
Frank
Old 12-03-2006, 06:37 PM
Originally Posted by frankgv
Thanks,
Frank
I am running a CF II in my '76 383 'vette. Feels just about stock as far as pedal effort.
Clutch pedal ratio? Super Chevy General Rodding Tech 5 04-13-2006 03:55 PM
Taurus SHO clutch issue... I know, big surprise... ViperMonster800 Transmission - Rearend 3 04-04-2006 09:33 AM
Clutch preload? RB401 Transmission - Rearend 0 08-03-2005 10:26 PM
hydraulic or mechanical clutch linkage? Pharmy Transmission - Rearend 5 03-31-2004 09:10 PM
floor mount clutch pedal 6speedwagon Transmission - Rearend 0 03-09-2004 02:45 PM
