Easy rear disc conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2004, 06:53 PM
I posted a few day ago about using the rear disc assy from a 90s Camaro on a 75 Camaro. Everything bolted right up except the rear axel flanges from my 10 bolt need to be trimmed 1/4 " for the rotars. I put the disc on a 10 bolt with 28 spline axels. It will also work on a 12 bolt. The axel lenghts were the same except the 90s Camaro uses 26 spline axels. You use all the parts from your original setup. If anyone has any questions pleas email me. Keith
