Easy way to remove tar insulation pad - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2008, 10:38 AM
Hi,
I have a 37 Dodge that has the tar insulation pad on the floor. I'm using a putting knife and razor blade at the present time. Is there an easier way????
Thanks in advance
Sam
Old 10-19-2008, 12:16 PM
powerrodsmike's Avatar
Wiki Edits: 161
I've had pretty good luck with a needle scaler if the tar is hard enough.
Mikey
BE different....ACT normal.
Old 10-19-2008, 12:22 PM
After you get most of it off, go to a building supply. Ask for the stuff the roofers use to remove tar from siding. Its a spray on solvent with a orange smell to it. Cuts roofing tar like a hot knife through butter. Tom F.
Old 10-21-2008, 08:26 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Two ways you can do it.
Wait till it gets colder out and use a stiff putty knife to break large pieces off. Or, warm it up with a gas torch from underneath and get your thin blade under it to start and slowly roll it back while applying heat to the leading edge.
I have made wide blade knives (2 -4" wide) that I inserted into my air hammer to remove undercoat, cold tar and tar board.
The trunk of my '37 Plymouth has a half inch of cold tar on it.
Loose Gm Tilt Steering Wheel Moves Up And Down fumplet Suspension - Brakes - Steering 10 05-13-2012 06:07 PM
Wetsanding/final buffing q's mpaq Body - Exterior 38 09-03-2009 12:15 PM
Easy ways to remove a body? GearheadSean Body - Exterior 9 07-07-2006 10:23 AM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 01:29 PM
Best way to remove body caulk and firewall tar? Gearhead forever Body - Exterior 7 06-18-2005 09:55 PM
