eaton differential question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2006, 03:23 PM
i have a question on a posi unit that i purchased.its used but in very good shape.the part#edb-30174.i have looked on the eaton site .but does not have any info on it .the guy i bought it from said it came from his 69 chevelle .its a 4-series carrier i was just looking into getting a master install kit for it .any help would be appreciated .also does anyone have the procedures for installing this unit .it will be my first time on a posi unit just wondering.
Last edited by jody chevelle; 02-11-2006 at 03:25 PM. Reason: adding in some things
Old 02-11-2006, 04:44 PM
Google edb30174 and you get hits like:
http://www.novaresource.org/axle.htm
http://www.nastyz28.com/camaro/zsusp.html
Notes like:
I have found out, through one of the chevelle clubs, that one of the first things to check is the spline count. The 12 bolt chevy has 30 and the oldsmobile that looks identical to the chevy eaton chunk has 31 splines. The same person gave me the series numbers for the three chunks they are: Series 2-ED32088, Series 3-EDB30140, Series 4-EDB30174. As to which series carries which gear ratio will be another post to come later.
Old 02-12-2006, 08:04 AM
reply on the info
Notes like:
thanks for the info i counted the splines there are 30 so its a chevy 4-series thanks
Old 02-12-2006, 11:50 AM
71C10's Avatar
U.S. Army Retired
Installation instructions are here: http://www.ringpinion.com/content/te...ult.asp?pid=69
Old 02-12-2006, 03:35 PM
thanks for the info
thank for all your help i appreciate it alot
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 07:35 AM
383 stroker 73monte Engine 10 12-05-2009 08:02 PM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
