eaton elocker - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2005, 07:46 PM
william27103's Avatar
eaton elocker
will this unit work in the 10 bolt that's in my 80 camaro, it's an 8.5" carrier...but i think it's for 30 spline axels instead of 28 spline, so i'd need new axels, correct?
http://www.automotive.eaton.com/prod...y/elocker.html
http://store.summitracing.com/defaul...=egnsearch.asp
a couple of links for info
hope you guys can set me straight
Old 10-28-2005, 01:09 PM
Yes. You will need new (30-spline) axles and I think you will also need new (larger ID) carrier bearings. Call up whoever you want to buy it from and make sure they send you the right bearings.
Eaton Compressors? daveh Garage - Tools 1 03-05-2005 09:09 PM
Eaton Compressors? daveh Body - Exterior 4 02-11-2005 06:41 PM
Will open ended gears work on an eaton posi unit? batman09 Engine 5 01-01-2005 06:26 AM
Eaton Posi Spring Colour Load ? FBody Transmission - Rearend 3 05-19-2004 06:19 PM
Eaton Posi for Ford 9" 302 Z28 Transmission - Rearend 0 12-08-2003 05:00 AM
