? Eaton G80 Gov Lock diff in GM trucks ? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-24-2007, 04:41 PM
The GovLoc is the only diff case that I have seen numerous (more than 200 myself) failures in vehicles that had no abuse(soccer moms in like new Tahoes?). My source tells me that GM uses the GovLoc because Eaton sells them to GM for $12. 100,000 at a time.
  #17 (permalink)
Old 06-28-2007, 12:01 PM
I have seen a few that went boom and heard of a few others. I have one in the 8.5" flavor my s10. It will get replaced once I have the money and time to do so because I am not a big fan of the gov-bomb. It acts like an open diff (jack up the back end and you can spin it by hand) and then locks solid after some 1-wheel-peel...that shock loading is what often causes them to throw chunks out the diff cover. My 125hp hasn't managed to blow it up yet...
If you want to know more about them take a look at the patents.
http://www.google.com/patents?id=FO88AAAAEBAJ
http://www.google.com/patents?id=2gg-AAAAEBAJ
Take a look at the drawings as well as the referenced by and citations.
This one was submitted in 69, approved in 74, and shows the governor (where the gov-lock got its name).
http://www.google.com/patents?vid=USPATRE28004
73-up trucks all (with I'm sure a very few exceptions) came with Gov-locks when ordered with the G80 build code. It was the 72 and older trucks that got "Posi" differentials.
GM, Wake up ! onenew32 Hotrodders' Lounge 73 09-24-2008 07:33 PM
HELP, Gov Lock Differential B-210 Transmission - Rearend 4 05-12-2005 06:34 PM
GM 10 bolt Diff ID numbers? Gearhead forever Transmission - Rearend 8 04-27-2005 08:45 AM
GM Front Diff. Reliability For Full Time Use. M&M CUSTOM Transmission - Rearend 4 10-31-2003 05:36 PM
HELP!!!! I need info on gm trucks!!!! trials_guy38 Transmission - Rearend 0 08-31-2002 03:46 PM
