? Eaton G80 Gov Lock diff in GM trucks ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2006, 06:06 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Anyone have any experience with the Eaton G80 gov-lock differential in the newer GM trucks/ suvs?
http://www.traction.eaton.com/prod2.htm
Trying to learn the pros and cons from your experiences.
Old 01-01-2007, 08:01 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
I know two people that have had issues, one truck was a year old and the rear locked up and the other was three weeks old when it did. Neither got any info from the dealer, one wouldn't know the difference and the other the dealer wouldn't tell him anything. Both were under warranty.
There are millions on the road, maybe theirs were isolated.
Old 01-01-2007, 08:10 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
G80 is the RPO that is assigned to any of the GM limited slip or locking diffs. The Gov-lock that you linked to is a bit misunderstood. It is basically an on-demand locker that uses a light coil that mechanically signals the clutches to lock up. Its like a limited slip that is open until excessive wheel slip triggers it to apply the clutches.
They are a heavy duty piece. If you tear one apart you'll find nice heavy internals along with this tiny little wimpy coil. The first reaction is to say that the coil will be the first to break, but in reality, the beefy cross spider gears are the first to go. Its rare to hear about the signal coil failing.
Lockers are open until you lock them together. Limited slips are held together by a viscous clutch all the time. The Gov Lock is what's in between; open for 90% of the time, but a viscous limited slip when needed.
Its a great street posi if you ask me. They get a bad rep because they don't hold up in high-hp race applications, but for street, towing, and HD trucks they are the cat's pajamas
Old 01-01-2007, 08:46 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
they work well when used as designed.
My gov-lock unit spit parts out the back cover on my 74 GMC 4x4 I owned many years ago. It was my fault , I over powered the diff
Old 01-01-2007, 09:43 AM
One problem with the gov lock is that if you spin up the rpm too quickly, the lockup mechanism may break. The locking mechanism engages when there is about 100 rpm difference between the two wheels. If you nail the throttle hard and go from 0 to 1000+ wheel rpm quickly it engages with a bang puts a lot of sudden strain on the locking mechanism. Its especially bad on dry pavement.
Bruce
Old 01-01-2007, 12:17 PM
xntrik's Avatar
G80 option. How do you know which type differential is installed in a 2006 Chevy HD2500 2 wd extended cab with 6.0 L??
Also have a 2003 ext cab Z71-1500 with off road and trailer package 5.3 engine 410 gears.
First one in HD2500 lasted 35,000 miles and locked up solid. Second one under warranty lasted 2,000 miles. Now it is out of warranty, so GM doesn't care.
No problelm with the Z71 at 60,000, but it's always had that driveline clunk that they are famous for. I think it is clutch disc limited slip.
I also know that Gov-Lock dis-engages above 20 mph.
Curtis you said,
..."on-demand locker that uses a light coil that mechanically signals the clutches to lock up. Its like a limited slip that is open until excessive wheel slip triggers it to apply the clutches." What kind of coil? electric?
Curtis you also said......"Limited slips are held together by a viscous clutch all the time." ????????????
Viscous limited slips are almost non-existent any more. Most all rear drives are flat multi-disc or cone Auburn style. I think that viscous are available aftermarket for front wheel drives.
75gmck25..... You said that they engage at about 100 rpm difference between rear tires. That seems high= and they disengage at 20 mph. A truck only turns 600 tire rpm at 60 mph.
thanks guys
Old 01-01-2007, 01:18 PM
curtis73's Avatar
Wiki Edits: 16
Curtis you said,
Its a mechanical coil that operates on centrifugal force. It looks kinda like a choke coil, but its not thermo-operated. When one wheel spins, the coil's inertia triggers the lockup. I wish I could be more specific, but I can't.
This is simply further evidence to the fact that I'm a dork. I misused the word viscous. You are correct that they are clutch style or cone style held togehter by spring pressure. Truth is, I just like the word viscous. Viscous, viscous, viscous.
I believe that the later trucks used the eaton-style clutch limited slip. Prior to that they used a cone style like I got stuck with in my Impala SS. The Gov Lock was usually reserved for the 14-bolt trucks.
P.S. viscous
Old 01-01-2007, 05:37 PM
I have a gov lock in my truck, but I'm no expert on how it works. This web site is where I found the info about engaging at about 100 rpm. It also explains why they can self destruct under extreme load.
http://www.offroaders.com/tech/limit...ferentials.htm
Bruce
Old 01-01-2007, 06:38 PM
xntrik's Avatar
.....I just like the word viscous. Viscous, viscous, viscous.
..... The Gov Lock was usually reserved for the 14-bolt trucks.
P.S. viscous
I did not get to see the HD2500 when it was apart. But I know the diff is a POS because it does not get abused, just used, and it has failed twice.
Eaton still manufactures their gov-lock and a disc limited slip.
Years ago wasn't Thorsen the manufacturer of viscous limited slips?
VISCOUS
Old 01-01-2007, 08:08 PM
Vortech 4.3's Avatar
jack of all trades
those gov-locks are total POS's. if i had one i would take it out before it cost me a tow. JUNK
Old 01-05-2007, 01:45 AM
74Ventura's Avatar
Good,Cheap,Fast.Pick Two
I have a gov-lock in the 12-bolt rear axle of my mud toy and have never had any problems with it,used to run 35" tires on a 77 4x4 with a 350 when I used valve float as my signal to dump the clutch in second now I've got 39.5" swampers on that axle in my buggy,less power now though,250ci Inline 6,automatic,and some more brains
Old 01-05-2007, 05:29 AM
we don't know the cause but we had the gov lock in our 72 4x4 and when we took it apart and it was still working there where pieces of ring gear in the bottom of the housing. changed out to a eaton limited slip Ed ke6bnl
Old 01-06-2007, 12:44 PM
Tribal's Avatar
THUG LIFE
I agree, the Gov-Locks are junk. I'd rather have a open differential than a Gov-Lock. The best posi's out there are the Eaton posi & the Auburn posi that uses the new cone clutch design. If you want something with a little more bite buy a Detroit locker differential or a lock-right that drops into your open differential. These can be a hand full in the rain / ice because the act just like a spool under power or engine braking.
Old 01-07-2007, 03:25 PM
xntrik's Avatar
Vortec4.3/ Tribal
Opinionated, But why?
Are these 2006 model parts as good or as bad as the mid 70s stuff lots of people complain about? But some have good service with?
If the GovLock has such an outrageously high failure rate at low miles...., why does Eaton still make them and GM still uses them on a daily basis?
I thought the premise on this Chevy board is that if the General makes it, that it is good. If the General doesn't make it..... it ain't worth %^&*.
Just because someone heard that someone's brother's wife's uncle's veternarian had one that broke is not a reason to condemn all.
I'm serious, not sarcastic.
GMC = got mechanic coming
Old 06-24-2007, 11:05 AM
Tribal's Avatar
THUG LIFE
The Gov-Locks are POS because they don't fully engage the clutches till the unit senses a slip, letting it act as a open diff till it senses a slip. That's when all hell brakes lose & the unit explodes. I've rebuilt about 15 rear ends due to the Gov-Lock exploding.
The GM Grenade-Lock. This one is from a '96 Suburban.
GM, Wake up ! onenew32 Hotrodders' Lounge 73 09-24-2008 07:33 PM
HELP, Gov Lock Differential B-210 Transmission - Rearend 4 05-12-2005 06:34 PM
GM 10 bolt Diff ID numbers? Gearhead forever Transmission - Rearend 8 04-27-2005 08:45 AM
GM Front Diff. Reliability For Full Time Use. M&M CUSTOM Transmission - Rearend 4 10-31-2003 05:36 PM
HELP!!!! I need info on gm trucks!!!! trials_guy38 Transmission - Rearend 0 08-31-2002 03:46 PM
