Eaton Posi - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2003, 08:05 AM
BILLCAT's Avatar
Eaton Posi
i had an auburn posi in my truck but it took a **** and a m looking at getting a new one. I was looking at eaton posi because they are rebuildable. anyone know if these are good and how often you have to rebuild them with everyday driving and the occasional burnout?
Old 09-26-2003, 01:13 PM
I have a Chevelle with a BB and I'm thinking about getting one to replace the stock diff in my 12-bolt. From what I understand it is a very good diff for a hot rod or muscle car. I believe they come standard with 400 lb springs and you can opt for 800 lbs if you are hardcore.
Old 09-26-2003, 07:12 PM
yah I agree the eaton posi's are excellent they are using a new type of clutch disk material that is suppose to be very very tough and the carrier is also apparently something like 30%o stronger than the factory units. you should be able to get a very good life span out of it even with fairly aggressive street driving. I certainly love mine.
Old 09-26-2003, 10:14 PM
I have a Detroit Truetrac in my truck, and I love it. It is a gear-type LSD, similar to a zexel-torsen. It is plenty strong and never needs to be rebuilt. It acts like a regular differential until you put some torque to it, then it locks up. You might want to check them out.
