Eaton posi 8.2 10 bolt? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2011, 04:36 PM
defilade's Avatar
2012
I want to put an eaton posi in my 65 el camino rear end am I correct that it is an 8.2 10 bolt for 65? It is going to have a zz430 clone with a pg behind it the crate engine manufacturer suggests 3.70 gear ratio will this work for street driven daily driver with minimal freeway usage?
Old 12-12-2011, 11:26 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You have the 8.2" 10-bolt rear end, providing it's original. A 3.73 rear gear wouldn't be bad if you avoided long trips on the interstate a lot (like you plan to do), IMHO.
You already know a TH350 would be a move in the right direction, I'm sure- so I'll leave that alone.
GM Eaton 10 Bolt Posi (good Kind Needs spiders) sjkonyndyk Transmission - Rearend 2 12-06-2010 09:38 AM
10 bolt posi Auburn vs Eaton sanman Transmission - Rearend 3 04-30-2008 08:04 AM
Eaton posi or not? oregon chevelle Transmission - Rearend 2 02-03-2007 08:23 PM
Eaton Posi BILLCAT Transmission - Rearend 3 09-26-2003 10:14 PM
eaton posi pin Robinson Robin Transmission - Rearend 1 08-18-2003 10:43 PM
