Eaton posi or not? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-25-2007, 04:58 PM
oregon chevelle's Avatar
Eaton posi or not?
I have a 3.08 posi rearend in my 66 chevelle. I am not sure it is the original but it is an original 66 rearend. Would it be an Eaton or maybe something else?
Old 01-26-2007, 06:04 AM
elvis 66 chevelle's Avatar
66 Chevelle 406 SBC
Eaton posi or not
Not sure what brand you have. i have a 1966 chevelle with a stock rear end 3:08 non posi. On the rear end tube on passenger side facing front of car there should be a number stamped on it. You can look this number up, it was the right number for my 3:08 10 bolt non posi!!!!!
Old 02-03-2007, 08:23 PM
Thanks elvis. I do have the Eaton posi.
Will open ended gears work on an eaton posi unit? batman09 Engine 5 01-01-2005 06:26 AM
Who has the best prices online for an eaton posi and gears? batman09 Engine 4 12-30-2004 08:57 AM
Eaton Posi Spring Colour Load ? FBody Transmission - Rearend 3 05-19-2004 06:19 PM
Eaton Posi for Ford 9" 302 Z28 Transmission - Rearend 0 12-08-2003 05:00 AM
Eaton Posi BILLCAT Transmission - Rearend 3 09-26-2003 10:14 PM
