Eaton Posi questions on application
Ok, I have a 10 bolt original rear end in a 69 camaro. It had like 2.73 gears in it before I upgraded to 4:10 gears a few years ago. If I remember right I had to change the carrier for the 10 bolt to support the 4:10 gears???
now I am trying to find the correct eaton posi unit but I think I want to drop down to a 3.73 gear instead of the 4:10. couple questions for you pros out there:
1) Will the Eaton work well for me before I spend the money?
2) What brand 3.73 gears do you suggest putting in?
3) With the 3.73 gears will I need another carrier for the eaton Posi or will the one I have work
4) Finally what eaton posi unit do I need for this application? I have been looking in summit Racing, but cant figure out which one is correct for me.
Sorry for the ignorance,but I am really new to all this set up stuff.
