Ebay re ring kits? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2012, 04:38 AM
Ebay re ring kits?
Im wanting to rebuild a 350 fairly cheap. i never used ebay parts before im i was wondoring if anyone had good or bad exp. from ebay. im wanting to get a re ring kit thats 60 bucks, a lunati cam kit thats 130 and a gear drive thats 50. Or should i spend the extra money at jegs??
Old 06-04-2012, 06:47 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Check out the rebuild 'kits' at Northern.
Old 06-04-2012, 06:49 AM
boatbob2
re-ring........
Buy your parts from Jegs,OR Speedway,or NAPA,but,buy american,the job you save MAY BE yours..Flea bay parts are MOSTLY built offshore ( China)
Old 06-04-2012, 07:03 AM
user151's Avatar
There are no "ebay parts," there are parts offered by ebay sellers -- which include jegs and other big names....
Old 06-04-2012, 07:04 AM
How fast is fast enough?
The parts you get in your kit are likely the same brands you'd find anywhere else. I've recently been convinced that moly rings are the way to go though I've used the cheap cast ones in the past. For the extra $10 get the moly facing though.
On bearings I only use King silicon allecular now. They've done well in everything I've used them in. Gaskets never really mattered much to me though a lot of people will only use felpro.
I would pay the little extra on the bearings and rings and go with a cheaper elgin cam kit if money is tight.
Old 06-04-2012, 07:45 AM
I buy all my Engine re-ring kits from http://www.ebay.ca/itm/Chevy-Chevell...item58942afd5d
FASTENGINEPARTS. You get Clevite bearings, felpro gaskets, and hastings rings..+ a Free Tshirt for $95.00 bucks. Good to deal with. Bought 8 kits so far, no problems. A re-ring kit in canada is about $377.00 "ouch"
Old 06-04-2012, 08:39 AM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Skip the gear drive and look up a good double roller timing chain.
Old 06-04-2012, 09:01 AM
if you're just doing a simple rebuild you probably don't even need a good double roller chain. I'd skip the gear drive though.
Old 06-04-2012, 06:42 PM
BigEd36's Avatar
I'm with Cobalt327, hard to beat the quality of the parts and the prices at Northern Auto Parts. Like AP72 said, Elgin cam kits are very affordable, so are Speed Pro.
Turbo kits dutch paul Engine 10 11-15-2009 12:17 PM
buying T-400 master rebuild kits from ebay. Billybong Transmission - Rearend 9 04-29-2009 11:13 PM
SCAT engine kits/parts on ebay AC/DC Engine 5 08-01-2005 02:46 PM
ebay trans rebuild kits speedfrk3 Transmission - Rearend 1 12-11-2002 04:07 PM
Dash kits redpl521 Hotrodders' Lounge 2 11-06-2002 11:49 AM
