ebay rotating assembly? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-20-2010, 02:38 AM
ericnova72's Avatar
More for Less Racer
10.5-1 is pushing it up there pretty good for a daily driver unless you use aluminum heads. I'd rather see it be 1/2 a point less for daily use, no sense pushing the limit on something like this. 10.5-1 can be done but requires cam duration to be rather large to keep the intake valve closing point late enough to not trap too much cylinder pressure at low rpm, resulting in a cam too rowdy for most people to stand for a daily driver.
The 12cc dish piston should put you just under 10-1, which would be real good.
  #17 (permalink)
Old 08-20-2010, 06:12 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Nevermind, this is another 383 deal.
Last edited by cobalt327; 08-20-2010 at 06:14 AM. Reason: Doesn't apply to a 3-3/4" stroke engine.
Assembly Rotating Problem Curtis Thornton Engine 29 05-31-2008 10:03 AM
383 stroker kit (Ebay) Hazard Engine 8 05-24-2006 07:51 AM
Ebay hoax troy-curt Hotrodders' Lounge 7 11-09-2004 01:09 AM
355 stiff rotating assembly Jared Engine 9 09-02-2003 07:20 PM
454 rotating assembly question BlackRat Engine 2 11-05-2002 10:38 AM
