Ebay SBC twin turbo setup
searching for headders for my '95 K1500 305 ( needs an exhaust gasket anyway ). I came across cheap turbo headders with a T3 flange.. I don't want to turbocharge the 305, but the 350 for my rat rod would be pretty cool turbocharged. I do have turbo experience.. I just can't afford a 'real' Garret Turbo, let alone 2 of them..
the headders seem well built, and there stainless. If they weren't up to par when I got them, I could still have them welded or reworked... the Turbo's, are just the basic Ebay T3/T4 hybrid, says 2 will work in a V8 twin setup, and there good to like 3.0L V6's on a single, so 2 should be good for a 5.7L V8. no compressor maps are available, so it's about as good a guess as that. but there like $160 each.. most of what I read about them, is to buy the rebuild kits, and rebuild and go thru them before using them, and then there pretty good when used with a genuine Garrett rebuild kit.. I would only want to run 8 PSI, or even a little less, but 8 PSI wastegates are pretty common ( don't want to intercool ).. is this a good idea? the engine which will probably get honed and re ringed/ new bearings, makes 8.5:1 compression with the current heads ( havn't looked at casting but will stay if there still in good shape ) and is pretty much a stock 1972 Chevy truck 350 4 bolt.. I wouldn't want too much HP, but if it would make 400 hp, that would be cool, being the turbo setup would cost about $800, and I could always save money for real Garrett turbo's built and sized for the setup I could just put a Caddillac air cleaner ontop of the 1850 Holley and call it good if I have to
I am actually building a twin turbo setup for my s10 using a 2 bolt 350 using two ebay turbos. They are the $129 ones....lol. I am just gonna take stock exhaust and weld on a flange. http://cgi.ebay.com/ebaymotors/ws/eB...m=160499865258 I am using stock replacement .030 over speed pro cast pistons. Stock rods and crank and am shooting for the sky......or until a rod comes through the side of the block or a piston explodes. im thinking shoot for 12-15psi and i am gonna slowly work my way up to maybe 20 but we will see how the pistons and plugs look. after a couple lower psi runs. Heres a little side reading on what some very careful tuning a a whole lot of luck can do....http://www.theturboforums.com/smf/in...?topic=61219.0 carcraft did an article on him.....http://www.carcraft.com/featuredvehi...ird/index.html |
it would be just as easy to limit the advance on a HEI. MSD 6 BTM would work great, but there $400.. 1 of the Summit Digital box's can be setup to retard timing at certin RPM's, which would also work
that's what I was thinking of..
the other concern I have is, these turbo's would be out in the open |
| Twin Turbo Small Block Chevy??? | chevyelc81 | Engine | 23 | 08-12-2011 01:46 PM |
| Who makes SBC twin turbo manifolds | KYLEdallas | Engine | 11 | 07-13-2006 11:50 PM |
| turbo SBC ? / lingenfilter ? | x007 | Engine | 20 | 10-03-2004 01:55 PM |
| Turbo SBC Rotating Assembly | KA67_72 | Engine | 7 | 07-02-2004 09:29 PM |
| Twin Turbo Camino | bjam2 | Engine | 10 | 07-03-2003 11:43 AM |
