Ebrake lines squaling - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2012, 06:29 PM
mitmaks's Avatar
Last journal entry: Grille
My brother is driving 96 lexus es300, recently it has been making squeal coming from rear tires. I narrowed it down to ebrake lines (they're inside of rubber insulator/protective line) I would have to remove brakes and hubs to get to it (hubs need replacing anyways along with shoes)
I was thinking I could spray some lithium grease inside line to lubricate it, should that work?
Old 09-25-2012, 10:01 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The pads have "wear indicators". This is a piece of metal attached to the pad that will contact the disc when the pads are at their service limit. It keeps you from continuing to drive until the friction material is gone and the disc ruined from scoring by the steel backing of the brake pad.
If the e-brake isn't releasing, the cables could be rusted and/or frayed inside the covering causing them to hang up. If the shoes have been riding on the drums, they're toast. If bad enough this can also cook out the wheel bearing lube and boil the brake fluid so be sure to flush the brake fluid, bleed the brakes and check the bearings while you're at it.
Personally, if there's a problem w/the cables, I'd prefer to see them replaced.
Old 09-26-2012, 06:31 PM
mitmaks's Avatar
No problem with the brake cables.
The problem is brake cables squeal ONLY when engaging/releasing parking brake.
Brake lines 80PontiacWagon Suspension - Brakes - Steering 12 01-10-2010 08:56 PM
What to do with old a/c lines jjupiter100 Engine 1 01-01-2010 07:00 PM
Turbo 350 fluid lines leaking is there better way to plumb lines? heathj1 Transmission - Rearend 3 11-08-2009 05:25 PM
Ebrake set up?69' C10 Chevy bonzipenguins Transmission - Rearend 5 02-01-2007 05:46 PM
in and out lines jalopy45 Transmission - Rearend 3 04-27-2002 06:43 PM
