Whoaaaaa there big guy, change one thing at a time. The brown cam is pretty well what I use on every engine I have built, I just wish they sold it seperately. I have to buy the whole darn kit just to get it, I must have 5 each of all the other colors. You can experiment but I always come back to brown. Black is standard.
If you have a bog check for zero clearance at the accelerator pump lever, the cam should start shooting gas as soon as the throttle moves...even a little bit. There will only be one hole position which will work well, can't remember which hole it is #1 or #2. Experiment and you will know immediately. Make sure there is 0.015-0.020" clearance at the override spring at WOT, you don't want to bottom the pump.
Once you have that sorted out you can play with power valves, I always use a valve that opens at 1 inch of mercury below what I see on a vacuum gauge at light part throttle (cruise), on mild cammed engines this is almost invariably a 65 valve. If you have a wicked 300 degree duration cam and open plane manifold with a big carb and big heads you might need to drop down to a 30. Factory stock engines usually use an 85 or 75.
If you can't get rid of the bog using these mods you might need a bigger shooter. The list of changes you can make is endless, just make sure you do one thing at a time. <img src="graemlins/nono.gif" border="0" alt="[nono]" />
Outlawed tunes from outlawed pipes
