Echeck, Metal-dust in oil, and burning headers!!! - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 07-28-2005, 05:07 PM
Jmark's Avatar
Maybe the outside bottom edge of a lifter? Whatever it is, it doesn't look good. Neither does the goo on your finger!
  #47 (permalink)
Old 07-28-2005, 06:36 PM
IROC_385z's Avatar
Someday it will work right...
The lifters are rollers so I don't think (sure hope) that it isn't from one of them.
The only thing that I could imagine that it is would be a spirolox; maybe one of them popped out? What troubles me is: what chewed it up so badly (it is half-missing) and what damage did it do elsewhere in the engine?
Saturday I will tear it down to inspect everything. I sure hope it IS a wrist-pin retainer because if not then...I don't know...
  #48 (permalink)
Old 07-28-2005, 07:32 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Ouch....that does look like the remains of a spriolock. Hope that one did not come loose. It will have ruined the cylinder wall for sure. Keep us posted.
Chris
  #49 (permalink)
Old 07-29-2005, 10:25 AM
IROC_385z's Avatar
I'm kinda worried about that too. <i>Where</i> is the other half of the retainer!! I can't wait to see what ate it up *hopes that the crank/bearings are all ok*
I have concluded that my camaro is Pandora, and the engine its' box...
  #50 (permalink)
Old 07-29-2005, 03:57 PM
that is bearing material -when it spins or locks to the crank the sharp edges of the block or rod jourals cut it off like a lathe
  #51 (permalink)
Old 08-27-2005, 09:03 PM
IROC_385z's Avatar
Hey guys! I was too discouraged to jump right in, but my girlfriend and I (you heard that right) finally took apart the engine the other day and I still have no clue where that shaving came from.
The cylinder walls are not chewed up, though I can see some up/down marks one a couple cylinders, nothing that would produce that metal. All spirolox are in place so it isn't one of them. The camshaft is fine. All bearings are chewed, but none look like they are gouged enough to make a big shaving like that...*shrugs*
I also noticed that the top inch-or-so of each cylinder shows a differant wear-pattern than the bottom part of the cylinder. Could this be from piston-rock since they are forged?
The only thing I wonder that could have caused the chewed bearngs is: I have the hi-volume/hi-pressure oil pump. The first cam I had in the motor let me rev to 7k+, which I did a few times. Now using the stock size pan, do you suppose that I sucked the pan dry and that is what caused it? I have read much argueing about if it is possible to suck the pan dry with such a pump...but at this point it is all I could imagine causing this?
What do you guys think?
  #52 (permalink)
Old 09-01-2005, 01:09 PM
IROC_385z's Avatar
Anybody have an opinion about the oil pump thing?
  #53 (permalink)
Old 09-01-2005, 01:55 PM
T-bucket23's Avatar
Wiki Edits: 26
bottom end
Sounds like the bottom end was never assembled properly in the first place. On a fresh engine you should have more than 10 lbs of oil pressure at idle period. I have seen a lot of rebuilds and have never seen glittery oil. I think you are fortunate that you decided to take it apart before you locked it up and threw a rod through the block. You should concider bringing it to a professional, have everything checked, repaired and re-assembled. Engine building is not an amature sport. You need a clean organized area to do the assembly work and a trained experienced eye to watch for potential problems.
Good luck with it
  #54 (permalink)
Old 09-01-2005, 03:07 PM
IROC, go back and review my post on page two of this thread. I believe you found what I told you was the problem : worn out bearings. How can bearings get worn out in 1500 miles? There was machine grit left in the motor after the recent machine work. It was left there because the shop did not revat the motor after the work and you probably did not clean all the oil galleys and passages adequately. I have had some bearings scored beyond limits during cam break in, after 1500 miles and high as 6000 miles, all because the grit was not adequately cleaned out. Obviously, we don't use the machine shop any more and we do a thorough cleaning before assembly that we did not have to do when the machine shops had better and more reliable help.
  #55 (permalink)
Old 09-01-2005, 03:25 PM
if the machine shop isnt putting your engine together ,the machine shop is not responsible for YOUR final cleaning before assembly.
  #56 (permalink)
Old 09-01-2005, 05:29 PM
IROC_385z's Avatar
I understand. I do not believe that he tanked the block after the machine work. Though I did power-wash it before assembly I can see how that would not get metal out of the oil galleys.
Note that the engine didn't always have such low pressure at idle, that developed after a short while. Initially I would have 45 at idle and 70+ while running.
About that oil pump theory: Nobody has commented about it yet. Assuming that 6500 is the max this motor will rev, should I stick to a stock pump or reuse the HV?
  #57 (permalink)
Old 09-04-2005, 04:59 PM
TurboS10's Avatar
Wiki Edits: 2
All the oil pump will do is rob a little power if it is HV. Sounds like you got the same treatment I got with my engine. I made the mistake of trusting the machinist when he said it was ready to assemble. He had left a large amount of crap in the oil galleys and it killed my bearings. Lesson learned!
  #58 (permalink)
Old 09-04-2005, 05:41 PM
Jmark's Avatar
That most likely is from, as stated many times before, metal crap from machining in the oil passages that was not properly cleaned out.
As far as the cleaning NOT being the responsibility of the machine shop IF they are not putting it together, I completely DISSAGREE! The block should be spotless inside and out no matter who is putting it together. If there is crap in the passages and the engine is trashed, i'd be going after the shop big time. There is just no excuse for crappy work.
Mark
  #59 (permalink)
Old 09-05-2005, 02:49 PM
and we all know when you buy dishs and silverware that we just pull them out of the box and eat off of them right then without washing them. so why couldnt we take an engine block home , set it in the corner until morning,then put it on an engine stand, let it set there another week ,then put it together and expect it to be clean,AND if it is nasty and our engine gets destroyed, lets call the machine shop and let the guys there laugh at us.then lets pour us a glass of milk in our new glass that we just bought without washing it and hope we dont get hepatitus. THE END.
  #60 (permalink)
Old 09-05-2005, 04:23 PM
Jmark's Avatar
Well, I don't have any 3 foot long gallery cleaners nor do I have a hot tank or pressure vat. Drinking from a dusty glass doesn't cost $2000+ compared to an engine going south from crappy machine work.
Ask TurboS10 about the post machining cleanout that the machine shop did NOT do. It cost him major bucks to make it right.
Mark
Oil filter Super Magnets? Jag Daddy Engine 59 02-01-2006 07:36 PM
M.S. requested joke thread hotrodit Off-Topic 186 12-20-2005 12:26 PM
oil pressure sending unit? Brian Morency Engine 2 07-21-2004 03:43 PM
Oil pressure loss SB Chevy Finmike Engine 30 06-12-2004 10:27 AM
rebuilt engine no oil pressure in oil galley bmedina103 Engine 9 10-07-2002 10:37 PM
