Echeck, Metal-dust in oil, and burning headers!!! - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 09-05-2005, 06:30 PM
first a hot tank or a pressure wash tank does not clean a block good enough for assembly. and if you dont have the proper tools for assembly (oil passage brush). then engine building should be done by the pro with the proper tools for cleaning which will be less costly.
  #62 (permalink)
Old 03-25-2012, 12:29 PM
IROC_385z's Avatar
Someday it will work right...
I ended up finding the source of the mystery metal
Many months later I randomly happened to find the cause of all these troubles...the friggin washer just above the cam gear on the HEI! I forget now why I was tearing it down, but I pulled the lower gear from the HEI and found that the washer was a very small and jagged shell of its former self. Didn't really cross my mind until I tore down a different HEI and saw just how big that wash was SUPPOSED to be! Somehow that damn thing got sheared off and cycled through the engine, trashing every bearing along the way.
I spent SO MUCH time and effort and money to make sure I did things the right way to avoid failure, and THAT simple little thing is what trashed my motor.
Unreal.
Oil filter Super Magnets? Jag Daddy Engine 59 02-01-2006 07:36 PM
M.S. requested joke thread hotrodit Off-Topic 186 12-20-2005 12:26 PM
oil pressure sending unit? Brian Morency Engine 2 07-21-2004 03:43 PM
Oil pressure loss SB Chevy Finmike Engine 30 06-12-2004 10:27 AM
rebuilt engine no oil pressure in oil galley bmedina103 Engine 9 10-07-2002 10:37 PM
