ECM buying tips - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-30-2009, 10:56 PM
ECM buying tips
I am looking for a computer to control the basic needs and nothing more. I just want something so I can add cruise control, anti-lock breaks and make the VSS I have on my 4L60 work. Anyone have any knowledge in findign something that will do the basics?
Old 12-01-2009, 07:01 AM
302 Z28's Avatar
Just about any VCM (vehicle control module) will work. The trick is going to be finding one that is not so complicated. All that use the 4L60E transmission will be limited to full size pickups, Tahoe or Suburban. All of those will have a myriad of inputs, vehicle speed, engine temp, throttle position, O2 sensor, anti lock brake sensor, anti knock sensor, the list goes on and on. I am not sure just how many of those you must have in order to get the transmission to operate properly. There are firms that make a computer specifically to use with the electronic transmission in rods without computers. Here is one example
Here is a good article on the 4L60 and 4L80 transmission that appeared in Hot Rod Magazine.
Vince
Old 12-01-2009, 09:44 AM
kleen56's Avatar
302's got some excellent reference here. VCM's are readily available, it finding the right one for your application that is difficult. There are several mechanics out there that specialize in just that and can often tweek or set up an unit that will work with your application. Sometimes it just beats going through all the headaches and can less costly in the long run.
Old 12-01-2009, 09:57 AM
First, most cars with antilock brakes use a separate computer to control them. Is your trans a 4L60 or 4L60E? There's a big difference in the computer needs.
Old 12-01-2009, 07:47 PM
Yes, all I have is a 4l60 but it does have an electronic VSS so I think I need a computer for that and the anti lock brakes.
Tips for shop layouts and tool purchases. schnitz Garage - Tools 9 10-18-2010 11:19 PM
Short guide on tips and viscosity. cjperotti Body - Exterior 15 06-02-2009 05:17 PM
Exhaust tips CrazyRoyExhaustfreak Engine 0 10-29-2006 06:04 PM
E-Bay buying tips EastCoastSBC Hotrodders' Lounge 11 03-23-2006 06:56 PM
NOTE ON Tips For The Devilbiss GFG-670 Plus gun x711 Body - Exterior 0 03-08-2006 06:51 PM
