Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ecm change=harness change?
Old 11-15-2012, 07:04 PM
LATECH's Avatar
LATECH LATECH is online now
Last journal entry: GTO Reproduction Hood
Originally Posted by chphlds View Post
one more question guys.when changing my ecm from the16198262 to the 16198259 will i have to change the harness also?
Your 86 F Bird is wired with a MAF sensor, the 16198259 is the correct ECM for that system. Unless someone radically changed the wiring , it should be plug in and play.
That was the point that I was trying to elude to about the difference in the ECM s . They look the same , but not all pins or terminals at the plug ins are used, depending on the type of FI system that it was designed to run.
The circuitry inside the ECM ( hardware) is different, and each one has a different wiring harness to hook to necessary devices under the hood.
As long as the underhood wire harness is intact, plug it in and go.
The #62 ECM has nothing inside that hooks to the terminals where the MAF sensor wires go in the ECM connector , because it doesnt use one. The ECM doesnt have the hardware inside to run it.
Fact is stranger than Fiction
The Following User Says Thank You to LATECH For This Useful Post:
chphlds (12-30-2012)
