-   Modern Electronic Engines (http://www.hotrodders.com/forum/modern-electronic-engines/)
-   -   ecm change=harness change? (http://www.hotrodders.com/forum/ecm-change-harness-change-226121.html)
chphlds 11-15-2012 11:46 AM
one more question guys.when changing my ecm from the16198262 to the 16198259 will i have to change the harness also?
LATECH 11-15-2012 07:04 PM
Your 86 F Bird is wired with a MAF sensor, the 16198259 is the correct ECM for that system. Unless someone radically changed the wiring , it should be plug in and play.
That was the point that I was trying to elude to about the difference in the ECM s . They look the same , but not all pins or terminals at the plug ins are used, depending on the type of FI system that it was designed to run.
The circuitry inside the ECM ( hardware) is different, and each one has a different wiring harness to hook to necessary devices under the hood.
As long as the underhood wire harness is intact, plug it in and go.
The #62 ECM has nothing inside that hooks to the terminals where the MAF sensor wires go in the ECM connector , because it doesnt use one. The ECM doesnt have the hardware inside to run it.
LATECH 11-15-2012 07:30 PM
Moving thread to Modern Engine Electronics .
chphlds 11-21-2012 10:23 AM
thanks for the info.my computer was down for a few days.really appreciate the advice.my first tpi and it is nerv racking.once again ,appreciate your knowledge.
LATECH 12-29-2012 07:16 PM
Bump to front : relevancy
