ecm change=harness change? - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 11-15-2012, 11:46 AM
Last journal entry: 34 street beast
one more question guys.when changing my ecm from the16198262 to the 16198259 will i have to change the harness also?
Old 11-15-2012, 07:04 PM
LATECH's Avatar
Your 86 F Bird is wired with a MAF sensor, the 16198259 is the correct ECM for that system. Unless someone radically changed the wiring , it should be plug in and play.
That was the point that I was trying to elude to about the difference in the ECM s . They look the same , but not all pins or terminals at the plug ins are used, depending on the type of FI system that it was designed to run.
The circuitry inside the ECM ( hardware) is different, and each one has a different wiring harness to hook to necessary devices under the hood.
As long as the underhood wire harness is intact, plug it in and go.
The #62 ECM has nothing inside that hooks to the terminals where the MAF sensor wires go in the ECM connector , because it doesnt use one. The ECM doesnt have the hardware inside to run it.
Fact is stranger than Fiction
The Following User Says Thank You to LATECH For This Useful Post:
chphlds (12-30-2012)
Old 11-15-2012, 07:30 PM
LATECH's Avatar
Moving thread to Modern Engine Electronics .
Old 11-21-2012, 10:23 AM
thanks for the info.my computer was down for a few days.really appreciate the advice.my first tpi and it is nerv racking.once again ,appreciate your knowledge.
Old 12-29-2012, 07:16 PM
LATECH's Avatar
Bump to front : relevancy
Recent Modern Electronic Engines posts with photos
Rear end gear ratio change = spedo. cable gear change. help? turbo 350 sugar ray Transmission - Rearend 6 07-18-2007 11:32 AM
Covert maunal column change to auto column change devious Transmission - Rearend 2 06-04-2007 01:10 PM
Harness and ECM ? Phoenix Down Electrical 1 10-02-2003 08:27 PM
ecm harness corsair Electrical 3 07-08-2003 10:02 AM
