which ecm do i need? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2006, 04:51 AM
Last journal entry: more one tonner
I'm planing on running mass air efi on my streetrod and need to know which factory ford ecm would be best for the job the car is fitted with a 302 and C4 auto. I've heard that the A9L ecm is the one to use, but this is for the manual 5 speed, will this work with the auto or should I chase an auto ecm and if so what is the code number that I should be looking for?
Thanks, Brian.
Old 09-06-2006, 09:32 AM
Last journal entry: 65 mustang 351w efi
you will find most everything you need to know here
http://fordfuelinjection.com/?p=5
I know I learned a lot from it. Now I need to go finish putting the disk
brakes on the Pony so I can try out the new intake.
Old 09-06-2006, 06:32 PM
Tominator's Avatar
That's a great site for information on Ford EFI.
I'll add that the A9L ECM is a family of ECMs.
http://fordfuelinjection.com/index.php?p=17
I'm using the A3M on my Ranger conversion. Get Mustang stuff if you can for the conversion as there is tons of info and help available and any 89 to 93 ECM will be in the A9L fanily.
That is really important if you plan on using a tuner and alter the MAF curves, etc. The tuners are not compatible with every ECM.
Old 09-07-2006, 03:20 AM
Thank's Guys looks like most the stuff I was looking for was on that web site.
Cheers, Brian.
Hey DocVette...ECM question Kevin45 Electrical 2 06-23-2005 06:49 PM
can't find ECM... gemini86 Electrical 7 02-08-2005 02:56 AM
Ecm BK455 Engine 13 03-12-2004 10:32 AM
Blowing ECM Fuse When Ignition Is Turned On aberg12012 Electrical 2 02-09-2004 04:31 PM
