ecm harness - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2003, 02:52 PM
ecm harness
swapping out v6 engine and th200 transmission in 1986 cutlass supreme coupe. installing chevy 350 and 200r4 transmission. what ecm should i use.
also will the engine harness and dash harness in the car now plug into the v8 ecm?
Old 07-07-2003, 11:53 AM
Stinkin_V8's Avatar
Suburbanite Member
Did the V6 have fuel injection? What kind - TBI, MPFI, etc?
What sort of fuel injection have you got on the V8?
When life hands you lemons, ask for tequila and salt
Old 07-07-2003, 12:40 PM
ecm
Appreciate help. The v6 is carbureted and the v8 I am installing will be carbureted.
Thanks, Jay
Old 07-08-2003, 11:02 AM
Stinkin_V8's Avatar
Suburbanite Member
Hmmm.. If they're both carbureted, there isn't going to be much that's controlled by that ECM. Maybe an electric fuel pump.. I think the electric fan is run from a temp. switch on the intake manifold. The tach signal is going to be different, but you should be able to fix that with a little fancy soldering - I think you only have to replce a capacitor on the circuit board of the tach (if you have one)
I don't know.. I would hook it up as close to the original V6 as I could and see what happened.
