ecm testing - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2005, 04:01 PM
ecm testing
I suspect that my ecm is bad can anyone suggest any places where I can have it tested. How much does testing an ecm cost?
Old 10-26-2005, 04:16 PM
docvette's Avatar
Wiki Edits: 12
Doc Here ,
Welcom to the Forum!
What are the symptoms ?
What Vehicle? Year, make model and engine size?
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 10-26-2005, 05:22 PM
Its an 89 camaro and the problem is intermittent. Sometimes it runs rough more noticable at idle and when the car is up to operating temp. I checked all my ignition primary and secondary wiring no fault found.
Old 10-26-2005, 05:39 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Have you tried pulling codes with a reader?
If you don't have one , go to your local Kragens or auto zombie, and they can run them for you..
You may not have an ECM or ignition problem at all..Depending on type of induction, you could have failing fuel pump, Clogged Fuel filters, air in the shrader valve, dirty injector (s)
You could also have a heat failure on a dizzy module..or a failing , dirty or Condensation locked Coil...
Pull the codes and see what it says..before you spend mega bucks on everything else..
Doc
Innovations
Old 10-27-2005, 04:29 PM
78novaman's Avatar
The AMC, FORD, & CHEVY Guy??!!
Last wiki edit: Improving fuel economy
Last journal entry: Finally on the road
All the 'zones around here only test OBDII vehicles ('96-up).
Your best bet is to find a pal that has an analyzer that can read OBDI GM, or visit the f-body forums to find out how to pull the codes using a paperclip (watching the dummy lights flash). http://www.f-body.com/
With that old of a car it could be any number of problems that, unfortunately, are going to be very difficult to troubleshoot online without specific codes.
Hey DocVette...ECM question Kevin45 Electrical 2 06-23-2005 06:49 PM
testing turn signal socket??? classic keith Electrical 11 04-11-2005 04:57 PM
90 Camaro RS Electrical Problem JulianSerna Electrical 8 05-19-2004 02:32 PM
Blowing ECM Fuse When Ignition Is Turned On aberg12012 Electrical 2 02-09-2004 04:31 PM
ecm harness corsair Electrical 3 07-08-2003 10:02 AM
