ecm type - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2012, 08:52 PM
ecm type
does any body know the type ecm a 1995 olds 98 has? unable to pull code with scaner. the connection appears to be obdii.
Old 09-03-2012, 11:39 PM
95 gm cars are weird the are wired obd2 and have the obd2 diag port but they are not obd2 compliant and the ecms are obd1. Most good code readers can read the codes but a generic obd2 scanner can not. I would take the car to a local advance auto or autozone and have them run the codes for you. I think you can do the old paperclip and count the blinks trick but i dont remember what pins need jumpered.
difference 305 ecm/350 ecm...need help thanx slipfreak84 Electrical 2 10-06-2008 10:07 AM
GM type 2 or type 3 power steering? dlc1979 Suspension - Brakes - Steering 0 09-22-2008 07:48 PM
ow do I check my ecm to see if it is a 350 ecm ghomer Engine 3 12-27-2006 08:51 PM
which ecm do i need? onepot Electrical 3 09-07-2006 03:20 AM
87 S-10 2.5 Ecm?? punk1c5040 Electrical 2 01-19-2004 07:51 AM
