econo disc help - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2007, 05:03 PM
econo disc help
got 40ford spindles, and need the adaptors for early chev rotors that the bearings go on, everywhere i ask nobody mails back, just want to sell new kit i guess, or does anybody have a kit lying around with al. hub they arent going to use. my kit was the econo orig, any help here.
Old 12-20-2007, 05:08 PM
NAIRB's Avatar
If you are using 73-77 GM rotors, you will use a Speedway bearing and seal adapter, part #91009301.
Old 12-20-2007, 05:44 PM
just looked at speedway and searched the part# and nothing came up, also im using the bolt on steering arm.
Old 12-20-2007, 05:55 PM
Youngster's Avatar
econo disc help
Call 'em! The service desk is open 'til 9;00 pm tonight. 1-800-979-0122
Youngster
Old 12-20-2007, 05:56 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Try Speedway number 910-31055
Old 12-21-2007, 08:03 AM
NAIRB's Avatar
I've been one of the street rod techs here at Speedway for about a year and half now. To be honest with you, I can't see where people save a whole lot of money by trying to use basic bearings, and getting their own stuff. From my expererience, most of our customers get the wrong rotors like Metric rotors or 69-72 rotors instead of the proper 73-77 rotors, or they end up with used junk parts. They end up frustrated and wishing they would have just purchased the whole kit. We offer several different kits for the early Ford spindles.
You can purchase a a complete brake kit for as cheap as $200.00.
Scrounging around junk yards costs money, and you end up with used parts, and the last time I checked, salvage yards aren't really overly cheap.
If you insist on going ala carte. You can use the bearing kit Henry Hi-Rise mentioned and the bearing and seal adapters I mentioned. You will need caliper brackets also.
Nairb
Old 12-21-2007, 06:25 PM
nairb, i bought the kit 15yr back, it is a magnum econo kit, same as your kit using chev rotors, lg bracket or thick cast, just the bearing adaptors need to be replaced, im not a moron totally, bodyman that built cars to go to cruise and barrat jackson, 35yr in the business, retired, didnt want to go to a machine shop just to machine the adaptors when you should be able to pick the phone up and in a few days be at my door. but even calling magnum , got their# through a freind, were no help at all, dont know if anybody ever had this problem ever but i do and no supplier gives a crap, all they want to do is sell a whole kit, you said $200 but where, all are $300+ for the econo and all i need is the adaptors for the bearings and yes i have the sense to look at bearing#s for replacement, anyway you are about right about replaceing the whole kit as you wouldnt have the hassel and i like the look of ALum, hubs with my rebuild, im rebuilding a old gasser that george potete owned in the past, i have had it for 25 or so years, being rebuilt from ground up with 4in chop, channel, new tube frame, 6in kickup in front,12 in rear, 9in in rear with 4bar all around, drop in front, glass tilt front, suicide doors, 31.18.5 in rear, destroked 350,reworked 350 turbo, oh its a prefect,51, cousin to the anglia with a 94in wheelbase, you know like junior thompson had. also i do all work myself or try to, 4dr into a 2dr, but i still need the bearing adaptors, 40 ford spindles, chev rotors and cal. also will have around $9000 total in it not $30,000+
Old 12-22-2007, 07:36 AM
31 five window
Last journal entry: grill and rear end
I have an extra set,They make 2 sizes, can you ckeck the I D of your rear bearing and let me know and I will see if mine are the right ones.
Old 12-22-2007, 09:56 AM
powerrodsmike's Avatar
Wiki Edits: 161
If speedydeedy doesn't have the right ones, (shhhh, you guys s'posed to do that stuff in the PM's ) You can give these folks a call,
http://www.braketechsolutions.com/BTSV101/Index.php
They're in North Carolina, real nice people to deal with, and the parts are good quality as well.
If you tell them just what you need, they may sell just the adapters to you.
Later, mikey
BE different....ACT normal.
Old 12-22-2007, 10:26 AM
Lost in the 60's
Wiki Edits: 4
You can buy just the adapters from Speedway....Narib gave you the part number...just because it does not show it on the web site does not mean they don't have them.....call thier 24 hour order number.
Old 12-22-2007, 10:58 AM
31 five window
Thanks I don't think I am doing anything Wrong as I am not trying to sell them just help a fellow rodder. But if i am wrong please explain because I really like this site and don't want to loose my priveledge.
Old 12-22-2007, 11:06 AM
Lost in the 60's
Wiki Edits: 4
I don't see where you did anything wrong.....you did not say they were for sale....you just said that you had some. Keep on keeping on man.
Old 12-22-2007, 12:07 PM
Wiki Edits: 161
I didn't say you were doing anything wrong speedydeedy, I could have misinterpreted the inference though.
Maybe the bigsmile happyface and the "shhhh" and the fact that I wrote "if speedydeedy doesn't have the right ones"...maybe all of that didn't come through as some joking around.
I do know that the guy in North Carolina uses domestic machine shops to make many of his parts that he sells , if I wanted to keep my money in the states I'd at least give him a call. Although I can't honestly say if those parts are made here or not. Speedway imports many of their products. Not to say they aren't good ones, I use speedway stuff all the time, but imported just the same.
Later, mikey
Old 12-22-2007, 12:36 PM
31 five window
No offense taken just not wanting problems.
Old 12-23-2007, 05:37 PM
sorry i havent got back about the posts, had a computer blowup, still havent got mail up and running or much of anything else but i found the board, thanks to nairb and others for advice on the parts i needed and i see i cant read either as they do have a kit for $200, must be why i am a body/painter not a mech, hahaha cant stand it, dont like the grease, i was trying to still use what i had, not going to say why i needed new adaptors, but after looking at everything i have most needs to be replaced anyway except for brackets. im old and hardheaded, oldschool guys are like that. ill try to make up my mind after xmas or so. when you have a project that everything needs to be made its harder to do. now got to see where the fuel cell can go, thanks a bunch
Ford Galaxie Disc Brake Conversion CrashFarmer2 Suspension - Brakes - Steering 5 04-10-2010 05:52 PM
drum to disc conversion kits dmented Suspension - Brakes - Steering 4 06-06-2007 10:06 PM
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 10:00 PM
Shrinking Disc, first time used dwhitt Body - Exterior 1 06-08-2005 08:54 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 04:34 PM
