Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Econo punch
Thread: Econo punch
Old 06-30-2006, 12:09 AM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
Wiki Edits: 161
Heres what I do with them.
I find it is easier to fit the hole tightly to the slug with a tapered ream and fuse the slug in with the TIG. Very little filler rod is needed. A couple of taps with a hammer and dolly then some grinding and very little bondo is needed to finish.
The weld on that 3/8" plug in the pic was done with a .040 tungsten with about 30 amps.
Sometimes for the bigger holes like in firewalls and radiator supports I go to the sheetmetal shop and fish around in their slug bin. .
Later, mikey
ID:	13031   Click image for larger version
Name:	slug in pan.JPG
BE different....ACT normal.
